another 92 CBR 600 f2 project
Old Jul 22, 2013 | 06:35 PM
  #21
Optimus_Prime's Avatar
Originally Posted by Artie Rivera
I also noticed that the reservoir did not drain when i pulled the hose.
I did a search for the proper way to drain the coolant, and it seems like i'm doing it right. I wish my temp gauge worked so i could see how hot it was. is there another way to see the temp? digital thermometer?
any help would be appreciated.
For the coolant reservoir, I seem to recall that you have to drain it separately by disconnecting the lower hose. It's most easily done by disconnecting the hose where it joins the radiator, on the top right, and lowering that hose so the reservoir can drain. Probably best done when you've drained the radiator at least a little so that doesn't pour out when you disconnect the hose! I believe the reservoir can't be removed without first removing the rear shock so it's hard to work around.
So do you know if you have a problem at your cluster of is your temperature guage not working because the sensor is faulty? The sensor is at the end of the black wire going into the right rear side of the cylinder head.
Old Jul 22, 2013 | 11:17 PM
  #22
Artie Rivera's Avatar
I pulled the sensor off and it seems like that is what is causing the temp gauge to not work.
That aside, The radiator is still smoking. I pulled the Thermostat off, it was broken as well. After i pulled it off, I started the bike up again after refilling the coolant. It still is smoking.
Anything else i'm missing?
Old Jul 22, 2013 | 11:37 PM
  #23
Any chance you got some coolant on the headers and it's just burning off as the engine warms up?
Old Jul 23, 2013 | 12:06 AM
  #24
well thats possible, but as the bike gets hotter, there is more and more smoke. It seems to only come off the right side of the radiator, where the cap is at.
Old Jul 24, 2013 | 12:01 AM
  #25
so I got the temp gauge working. The smoke was the high temp paint I put on the radiator and headers baking. also all the coolant I spilled all over the radiator. I took her for a run today and the temp stayed within operating levels. This means I can continue the restoration process. Still hoping for a friday ride!
Old Jul 26, 2013 | 12:28 PM
  #26
Well I'm about 98% done with this project. Bike runs great. Filled her up this morning and rode to work, about 15 minute ride, but still was lots of fun.
here is the last of the pics for now!
Added front fairings and decals. frame sliders new handle grips and bar ends. also new levers. I had a great time fixing this up. kinda sad its over, but at least now I get to ride it! haha thanks everyone who kept up with the thread! If you have any questions please ask!
Old Jul 26, 2013 | 02:16 PM
  #27
sickcbr1k's Avatar
Wow that is some transformation right there! Gret job man, lookin awesome
Old May 27, 2018 | 09:45 AM
  #28
Robbob4027's Avatar
Default Hi
I recently got a 92 cbr f2 and wanted to know if you could help my bike didn’t come with any plastics including the rear fender / plate holder I was wondering if you could send me some pics of how the rear fender mounts to frame under the seat I’m having trouble figuring out how it goes because the side fearing mount to it and and just trying to see if I’m missing anything and if you know of any places that my have used parts for this bike
thank you for any help you can give
suavegav
Apr 15, 2013 04:55 PM
patpatpat
Jan 31, 2011 04:42 PM
axpaj345
Aug 8, 2010 05:15 PM
Cuzy
Mar 7, 2010 05:41 PM
edccbr1000
May 2, 2009 08:24 AM
