Aftermarket rearset alternative
Old 01-23-2008, 08:51 PM
Dj_Squatch's Avatar
Default Aftermarket rearset alternative
Ok everyone....i was looking for some decent rearsets, checked out vortex and woodcrafts...and after some thought...i said to myself.......i dont want to spend $200 on fn rearsets....so i remember seeing some riser plates for gsxrs that did the same thing using the stock rearsets, and thought...why dont they make these for f2s...so what i did was get some steel (i think it was about 1/8th??) something not too heavy but to make sure it could hold all my weight.....and then cut a peice about 4" by 5" and then traced the holes on it and drilled them out..When mounting them if you decide to do this be sure to put two sets of washers between the frame and plates so it will clear the swing arm...especially on the rear brake side. Then for the shift lever you have to get one of those little long threaded bolt things and then a peice of treaded rod. I found some at homedepot...wich I think is around 2 dollars? Point being that i spent a total of 2 dollars plus tax and got a little over a inch in height increase for the pegs, inch and a half or so further back...and a little more aggressive angle, and got to fit it to my liking for 2 dollars and a little over two hours total....screw 200 dollars. Ill post pics once I take off some of the excess metal on them and get them powder coated.
Old 01-23-2008, 09:14 PM
Default RE: Aftermarket rearset alternative
post pictures before too so i can picture this better
Old 01-23-2008, 09:32 PM
Dj_Squatch's Avatar
Here is what I got the idea from....ill get pics in the next few days...sorry my bike is out at my dads.
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29
Old 01-24-2008, 12:33 AM
Sand.Man's Avatar
What are you doing with the shift and brake levers?
Old 01-24-2008, 07:21 AM
kjohnson's Avatar
I've got something like that in my spare parts bin.I'll be getting them back from a fabricator this weekend.I'll post pics as soon as I can.
Old 01-24-2008, 11:21 AM
SpecR's Avatar
ORIGINAL: Hershey
The brake would be unaffected, but he'd need an extention for the shift lever.
Old 01-24-2008, 01:24 PM
Dj_Squatch's Avatar
I found just some threaded rod and some of those long double sided nut things at home depot..i pulled off my shift rod and am going to go see what fits today....the only thing that is a little tricky is getting the holes drilled right and having enough clearnce between the swing arm and the backside of the brake lever...couple washers fixed that.
Old 01-24-2008, 03:26 PM
SpecR's Avatar
The stock shifter rod has reverse threads on one side, so that's not going to work.
jjbtao
How-To: Mechanical
52
05-10-2012 08:26 PM
Jaybird180
11-02-2008 10:06 AM
speedra500
01-31-2007 07:25 PM
Quick Reply: Aftermarket rearset alternative
