93 NO START need help please
Old Jun 27, 2010 | 09:19 PM
killbillsnj's Avatar
Default 93 NO START need help please
i have a 93 f2 and when i got it it ran fine nothing wrong with it other that clutch lever and handle bar
now one day i wake up and it doesn't start
it has spark
i took off the tank and sucked on vacuum hose and gas came out
if i spray starting fluid into top of carbs under air filter it runs
cant figure it out maybe some one can help me
Old Jun 28, 2010 | 06:50 AM
JesseAwesome's Avatar
Well it's got spark, and the motor is fine. Sounds like something is going on in your carbs or fuel lines. Clean the carbs out, then fill the bowls and run it without the gas tank on (setup a beer bong gas delivery system). That eliminates the tank and the fuel lines from the equation, not that there is much to them.
Old Jun 28, 2010 | 06:37 PM
C Average's Avatar
yeah has to be dirty carbs. after cleaning mine what I thought was good it still had the same problem. Till I got down inbetween every hole on the jets with a little wire.. Ive learned now. If your gonna take them off. Take your time before you put them back on. cuz theres nothing worse than taking em off more than once
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
