'93 F2 Mods - Phase 2
Old Aug 28, 2013 | 01:41 PM
  #341
Mattson's Avatar
Sorry I keep bothering you about the gauge but since I have the chance to get first hand info on such an expensive part I have to exploit it...
Can you clarify how exactly does the color change work, it won`t change every time I turn the high beams on does it? Was thinking like does it change by a fast hi/lo flip? Cause then it should change color every time I flash the passing lights too?
Old Aug 28, 2013 | 01:56 PM
  #342
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Originally Posted by R3define
I'm such a sucker for Red lights. Haha. But that white looks nice too.
The reason I figured I would like white the best, is simply because it will closest resemble the style of the OEM tach.
The white background on the other side, well, it doesn't really matter, because I've got to get used to a digital display now anyway, AND the fact that now the speedo's on the right side of the tach.
Being happy with the way the tach looks is key... having a speedo is a bonus, but in races, it's just the tach and coolant temp I'll be looking at.
The truth is, I may not end up using either color, or might have to change depending on the sun's position, to find the color that gives me the best viewability for the conditions.
Keep it up man. At least you've pulled the tank just a few times so it shouldn't be so bad.
Yes indeedy I have, but I'm to the point where I'm ready to sew this thing up and be done ... until the next bug bites, anyway!
Old Aug 28, 2013 | 03:11 PM
  #343
JNSRacing's Avatar
Well, I honestly haven't tested it completely yet, I have only used the high beam toggle operation, to change the color before starting the bike - it's possible that the setting remains, once the bike is running, so that you can use the high beams, without changing it, but about that I am not yet certain... I'll test this theory tonight.
I don't know anything about flashing passing lights, as U.S. bikes don't have any such feature.
Now, bear in mind, that I no longer have a high beam switch even present, so you don't have to wire the Koso high beam indicator wire, to the actual high beam switch, you could do what I've done, and just run a simple switch for this operation only (changing the display color).
With my setup, however you would not be able to rely on the gauges high beam dash indicator, but that wouldn't bother me personally on a street bike, as I KNOW when my lights are on low or high beam - it's obvious.
Old Aug 29, 2013 | 09:54 AM
  #344
JNSRacing's Avatar
Well, unfortunately the tach still does not function properly, even after implementing the steps recommended by Koso support yesterday.
I had already established the ground straight to the battery, since I had read about others that were advised to do so, then I tapped into the yellow wire from the pulse generator, and begin to test.
Starting with 1P (1 piston), and working my way up to 12P, I found that as I went higher in number, the readings got closer and closer to good, but even on the best setting (12P), it only read correctly at idle – when I rev the bike to what I know is about 6k – 7k, the tach reading is topping out at 15k, and when I would then rev from holding at 6 – 7, to what I know is about 9 – 10, the tach needle is falling back to the bottom of the range.
I’m going to call Koso again today, during lunch, and inquire again about the filters they used to send out, as those instances I’ve read about, where a filter was sent, the issue was usually resolved… this is very frustrating.
Old Aug 29, 2013 | 11:11 AM
  #345
gtcole's Avatar
Welcome Crew
Damn. Most ppl I've read about on other forums wired it to number one coil and set it for two p
Old Aug 29, 2013 | 11:47 AM
  #346
JNSRacing's Avatar
Well, I also tried the inductive pick up method, wrapping the wire around the actual spark plug lead, but with the instances I read about, it didn't matter if they tried that or used the coil wire! I need to search for more occasions of this, I guess.
In the instances you read about, were some of them 4 cylinders, or were they all V-twins?
What annoys me, is that the instructions give you an option (and it IS the simplest option), of just wiring directly to the OEM tach signal wire, from the CDI - the chart in the instructions even correctly identifies that the Honda RPM wire is yellow/green! This wire works just fine with the OEM tach, so an appropriate filter to "clean up" the signal, so that it can be used by the Koso tach, seems to be a good idea to me, especially if this worked in the past, and they used to furnish them to customers.
Old Aug 29, 2013 | 12:17 PM
  #347
gtcole's Avatar
Welcome Crew
Those were instances specific to the koso and f2. When I get home I'll try to find my bookmarks an send em your way
Old Aug 29, 2013 | 01:07 PM
  #348
JNSRacing's Avatar
Awesome, thanks... I hope you can find them!
Old Aug 29, 2013 | 01:41 PM
  #349
JNSRacing's Avatar
I spoke with Koso tech support again, at the beginning of my lunch hour, and reported the results of their suggestions - a rep called me back moments ago, and reported that they are going to send me a filter, to be used in-line with the Koso RPM wire, and the positive probe on the coil... he said it will ship today.
Old Aug 29, 2013 | 01:44 PM
  #350
gtcole's Avatar
Welcome Crew
Good. Hoping this works out for you. I'd be interested in how the filter is made lol
