'93 F2 Mods - Phase 2
I'm glad you asked that, since I haven't calculated it in a while!
With all the changes to the race bike, due to lighterweight components, removal of no-longer-needed items, AND taking in account the weight gained with items like the heavier shock, frame sliders, heavy duty engine covers, caliper relocation brackets, paddock stand spools & mounts, etc., the current weight reduction from stock form, is:
That's not easily answered, as most of these changes took place gradually, one part or one change at a time. There were some items, like the battery, and the slip-on, where the weight reduced was significant enough to notice it immediately, but for the most part it's been gradual.
Now as far as the difference right now, I don't yet know, as I've not ridden it following a good bit of these changes, BUT, what's great about my current situation, is that NOW I have a stock bike (mostly) that I'm riding daily, so when I get on the race bike again, it will be VERY obvious, I'm sure!
47 lb. 9.78 oz
Thanks, and very true what you said... function takes precedence in racing, but form usually comes tagging along, shortly thereafter!
But yeah, the first event I make it to this season, I'll be feeling the difference... mega!!
Look up things like adjusting the ride height, which can be somewhat changed with just pre-load, but can be more specifically set by changing the position of the forks in the triples, and adjusting the ride height of the shock (only with aftermarket shocks). Look up setting the proper "sag", front and rear, getting the forks and shock "sprung for the rider's weight" (with gear), and then making further adjustments to pre-load, compression dampening, and rebound dampening, until the suspension performs the best, based on the rider's preference, the kind of riding, and the track/road conditions. Bear in mind, some of these settings are not available on stock F2 suspension components.
Small update...
I further trimmed down the aluminum bracket I use for mounting the upper rear portion of the race tail, and since I've been kind of "polish happy" lately, I polished the piece, just since I've got the stuff to do it.
I got the race ignition switch mounted and wired in.
Works wonderfully, and shaved some more weight, just over 1/2 pound.
Where did you get the revised cluster glass from? My cluster is in the worst of worst conditions, but every time I search ebay they are also either broken or waaaay over priced. I was thinking about doing a cluster swap but I really dont want to go thru that hassle right now since I still have other thing to do to the bike first.
Nope. It is part of the original cluster assembly - I already had it - the only thing I removed, is the black finishing piece, that goes on top of the whole lot.
Now if you're asking if you can get it from a dealer, then yes, it is part # 37102-MV9-601, and is a touch over $30
Underneath that is part number 37130-MV9-601, which provides a seal of sorts to each of the guages, between the main cluster base, and the clear lens... strangely enough, Honda calls this part, which is a combination of black plastic and rubber, "Plate, reflecting"
There are six screws, part # 92903-24520, which go through the main instrument "case assembly", from the back side, through the above mentioned parts, and tighten into the black bezel, or shroud - Honda calls it the "visor assembly".
Bad wording on my part. As far as the suspension goes what exactly do you mean? (I'm still learning, this is my first bike)
