1994 CBR600f2 with F3 motor
Old Jul 11, 2024 | 11:17 AM
Shortty's Avatar
Default 1994 CBR600f2 with F3 motor
I've done lots of digging but still aren't confident that I have all the information. The story is I've bought a 1994 F2 with a blown motor. I found a 1997 engine near me but am not sure if it will be a direct swap. What I've learned is they have different carbs, F3 has a fuel pump, ram air and carb cooling. I'm hoping if I use the carbs and electronics from the F2 would the F3 motor work properly. I'd use the waterpump cover from the F2 and apparently there's a line from the case I'd have to block. If I did that would the swap work? Otherwise I found a 93 engine further away...but I'm not as confident in its condition
Old Aug 2, 2024 | 11:00 AM
Shortty's Avatar
Default Thread for joint hose
Does anyone know the thread for the joint hose that comes from the bottom of a f3 thermostat casing. I'm doing a f3 swap in my f2 and don't need this line as it goes to the f3 carbs. I just want to plug it
Old Sep 15, 2024 | 01:14 PM
f2.5's Avatar
i have an f2 with a full f3 engine and wiring harness with the carbs. seems like with the f3 carbs you have to pull this thing off the bottom to service them…tps hits the frame
itsahurricane
F2 Tech
Dec 4, 2012 06:17 PM
cbrtaz64
Mar 7, 2012 07:26 AM
moto_addict
Jan 17, 2009 08:00 PM
ClayRay
Dec 16, 2007 09:16 AM
