F2 engine troubles
Old Dec 10, 2007 | 01:21 PM
ClayRay's Avatar
Default F2 engine troubles
Besides 1991-94 engines, will any otherengines fit in a '94 F2without much modification?
Old Dec 11, 2007 | 09:48 PM
kjohnson's Avatar
Default RE: F2 engine troubles
95-98 F3 motor will "pop right in".When you go to the F3 carbs and airbox,you'll have to cut the tabs on the frame's upper crossbar if you want to use ram air.I don't know if you need to use the F3 radiator or not.
You can use the F2 carbs and airbox on an F3 motor with no problems.
Remember,if you go to the ram air setup,you will need a fuel pump.I learned this the hard way [:'(]
Old Dec 15, 2007 | 04:00 PM
crashingsucks's Avatar
Is there any advantage/good reason to go with an F3 motor in the event you ever have to replace a motor?
Old Dec 16, 2007 | 09:16 AM
kjohnson's Avatar
The head and transmission are better with the F3 motor.Head flows better,the tranny synchro is closer together.The transmission bearings are better in the F3.Also,the bottom end of the F3 motor is beefier (stronger).The con-rods and journals on the crank are stronger,not that the F2s will break.
Best of luck,and let us know of any more snags/snafus.
bakesteak
Apr 15, 2009 09:17 PM
tmihaylov
Dec 21, 2007 10:04 PM
steward231
Sep 22, 2006 07:49 PM
Custom900
Aug 30, 2005 01:43 AM
