1993 F2 throttle sticking
Old Feb 8, 2005 | 11:10 PM
adrunpants's Avatar
Default RE: 1993 F2 throttle sticking
As the cables get older they are prone to sticking due to them flattening out where they protrude from the front of the airbox.
The main fix for it is ...
Remove the airbox & locate the front mounting point on the frame(for the airbox mounting lug) and bend it up slightly to relieve the downward pressure on the throttle cables when the airbox is in place.
It may also help by gently squeezing the outer cables back into shape with pliers (as they do flatten and bind after time).
[IMG]local://upfiles/455/E3682075A340463185854ED050EC092C.jpg[/IMG]
Old Feb 10, 2005 | 11:13 PM
Nipz's Avatar
I just got some new cables. so we will see if that fixes them.
Nipz~
Old Feb 20, 2005 | 08:53 PM
Nipz's Avatar
New cables, new throttle sleeve and still no good. mad sure the cable was not to tight.It is now very smooth but i have to replace the throttle return springs in the carbs to get it to snap back. right now it slowlty come back. take about 1sec -1.5 to return.
Nipz~
Old Sep 3, 2005 | 05:59 PM
TheFleshRocket's Avatar
ORIGINAL: ezl_oo
I fixed my throttle I just opened up the control box where your engine off and on switch is and took off the grips and sprayed wd-40 into the throttle cable that makes it snap back and it worked it is perfect know.
This is exactly what fixed my F2's sticky cable after it sat for about a year without being ridden. It went from being dangerously sticky (as in pretty much unrideable) to snapping back just like it should. It did take a good bit of WD40 in both ends of the cable but it did the trick.
Old Oct 13, 2005 | 11:42 PM
93CBRdude's Avatar
I just bought a 93 CBR 600 about a week ago. My throttle was sticking also. what i did was i removed the bolt from the side of the grip and found out that the rubber washer in there had deteriated and was gumming up the throttle. I cleaned that up and put in a new washer and it snaps back perfectly now.
Jonnywright
Jun 3, 2012 07:06 AM
sawnee
Dec 20, 2008 04:44 PM
KLO
Oct 27, 2008 07:40 PM
MikeZ
Apr 1, 2008 03:17 PM
BW
Jul 4, 2007 02:07 PM
