1993 600 F2 wont start
Old Nov 12, 2006 | 01:11 PM
oakbri's Avatar
Default 1993 600 F2 wont start
Hi guys and gals
Just wondering if anyone can help me. My 1993 CBR 600 F2 wont start. I had it ticking over warming the engine and the motor stopped. The fuel is on, battery fully charged etc etc.
I looked at the plugs they seem ok. I then sprayed easystart directly into the carbs whilst turning the engine over and it still didnt fire, which can only mean there is no spark.
Any help would be very much appreciated.
Many thanks
Old Nov 12, 2006 | 02:39 PM
mk3turbo's Avatar
Default RE: 1993 600 F2 wont start
did you check your coils?
Old Nov 12, 2006 | 03:40 PM
oakbri's Avatar
No I didnt check the coils, looking at them there appears to be 2 colis, each powering 2 cylinders. If a coil failed would the other 2 cylinders not still fire on the remaining good coil?
I did a resistance check on the pulse generator and it appears to be OK.
Old Nov 13, 2006 | 06:34 AM
mikequinn's Avatar
If the motor was running fine then just cut out , it'll be something simple... try swithcing the fuel tap onto reserve.. if not check to see if a fuel line is kinked or trapped.. dont spray easystart in her, the engine can't cope with the raised compression when you do that, it's a motorcycle not a 14 ltr diesel engine,
Brandon Simmons
F2 Tech
13
Feb 19, 2014 04:16 AM
C Jacob W
Jul 29, 2013 11:03 AM
blacken77
Mar 28, 2013 08:58 PM
curt93900
Feb 11, 2009 08:47 PM
tagger609
Jun 27, 2008 02:09 PM
