What to do w/ my 87 Hurricane?
https://cbrforum.com/forum/cbr-600f-...-color-144273/
https://cbrforum.com/forum/cbr-600f-...1990-a-128286/
I'm thinking either the spark unit isn't receiving a signal from the trigger wheel, or there's loss of battery voltage to the coils or spark unit. Not sure if there are any adjustments for the trigger point gap, but should be in the manual somewhere.
I don't know if I am missing something here, but why not just do a simple spark test? Ground the plug on the case and see if you get spark.
If you have spark and fuel delivery, maybe a compression problem. Smell the oil, if it smells like fuel, you might have been dumping too much fuel in the cylinders and washed all the oil away, leading to no compression.
OK heres the deal. I finally got back to this thing a few days ago. I took the pulse cover off, looked at it, took the timing wheel nut off and looked at that, put it back together and it fired up no problem. LOL No idea what was wrong.
So the spark is fixed.
I took it for a ride earlier today (yes i know its 30F outside), the new problem is now 2nd gear pop out.
So now the question is... Should i put the trans parts from the old motor in the new one? Or put the crank and bearings from the new motor into the old one?
hurricanematt
08-09-2019 12:21 PM
