what can i do if the throttle handle sticks
make sure your throttle grip is not hung on the bar end weight. unscrew the switch/throttle assembly and flush the cable housings with wd-40 or brake cleaner and then relube and adjust. you may want to put a rag at the end of the cables near the carbs to catch any muck coming out of the cable housings. i would also spray down the throttle spring assembly on the carbs. make sure the spring return is snappy.
