Valve adjustment woes
Old Sep 5, 2009 | 09:49 AM
Five's Avatar
Default Valve adjustment woes
Decided to adjust valves last night. It has been about 20 years since I've done an adjustment on a Hurricane, so I decided to make the job easier and picked up a set of Motion Pro tappet adjusters...didn't help, they are useless on the Hurricane as the tool is too short to turn the lock nuts.
Anyway, it was going well with standard hand tools and I had 11 or twelve valves done and was breaking loose the lock nut on one of the #2 cylinder exhaust valves and the whole freakin' rocker arm came out. So, I went inside, took a shower and said screw it until morning.
So today I get to pull the exhoust cam and see if I can get it back together or if I need to replace the holder spring
Has anyone else had this happen?
Old Sep 5, 2009 | 07:28 PM
andvari101's Avatar
Can all of that be done with the engine still in the bike? Or do you pull it out to do all that?
Old Sep 6, 2009 | 12:11 PM
Five's Avatar
It was all done with the engine in...pulled the exhaust cam got it all back together. seems to be ok now.
Brewha929
Feb 29, 2012 10:43 PM
94excoupe
May 9, 2011 07:19 PM
dienasty13
Sep 15, 2007 08:48 AM
UKDavid
Sep 2, 2006 10:03 PM
husker1600f4i
Jul 29, 2006 10:09 PM
