Swingarm spools
Old Nov 26, 2010 | 07:10 AM
Five's Avatar
Default Swingarm spools
Anybody ever add them to a Hurricane? If so, what did you you do? I have some ideas, but was wondering what worked for others.
Old Nov 29, 2010 | 04:50 PM
michigan_313's Avatar
i've never done it to a hurricane, but i have done them for older katanas. same idea though. i got .5" diameter steel rod, cut spools mounts to cross-section size of swingarm, drilled and tapped the center, and then welded it to the swingarm a little more than an inch in front of the adjustment slot. that way the swingarm stand doesn't interfere with the axle bolt when all the way forward for chain adjustment. i did the welding with the swingarm off the bike. also, removed any grease, oil, paint, or coatings so that i get to clean bare metal surface before welding. when finished i get some krylon to cover up the bare metal.
cbninjar02
Mar 12, 2008 01:48 PM
fireplug
Sep 4, 2006 07:35 PM
MOF4
Dec 15, 2005 09:23 AM
sikanimator
Dec 2, 2005 11:55 AM
APCh8r
Nov 28, 2005 07:46 PM
