Soft Forks on '88 'cane
Hi there,
My first post on here. I'm a long time Honda bike owner and have had a couple old ones. My first was a 1986 VF500, and my 2nd was a 1986 VFR750.
Anyhoo....my good friend just purchased a 1988 Honda CBR600F with aprox 38,000kms (23,600miles). It needs a bit of work but the one thing that seems a bit odd is the front Forks.
Sitting on the bike, with the front brake held I can very easily compress the forks. I rode the bike and the front end does feel a bit light. (I'm not a heavy guy either...about 145lbs)
I don't feel or see any Fork Oil around the Dust seals.
Possible the forks are just tired? No oil left?
What is the general oil weight used when refilling them?
Hey slowbird, welcome.
Here are the specs from the Repair Manual.
When sitting on the bike.
Right Fork Capacity: 361cc (12.2 US fl Oz, 12.7 Imp fl oz)
Left Fork Capacity: 371cc (12.5 US fl oz, 13.0 Imp fl oz)
Oil Level (Both Forks): 120mm (4.7in)
Oil level is measured from the top of the tube with the fork spring removed and the leg fully compressed.
The fluid is ATF (Dextron/Mercon)
You can also add anywhere from 0 to 6 psi (0 to 0.4 Bar) of air pressure to stiffen the forks.
Last edited by tds94probe; 07-24-2011 at 09:54 AM. Reason: Found air pressure specs.
you can also cut some spacers out of pvc or copper tube. about 3-4 inches long, and install them above the springs. that will help a little if the springs have worn out. you might also try using actual fork oil, they sell it in different weights. first thing you should do is make sure there is oil in there.
