Rough idle
My 90 wont seem to hold a steady idle. it will idle at around 1200 then will jump up to 2000 then fall back down and sometimes stall out. My dad took a look at the bike and he said it sounds like one of my cylinders is misfiring. My carbs were just synced and completely cleaned and new plugs were installed. Sometimes the bike starts to run on all cylinders, you can hear when it does and thats when it revs up by itself. It also seems that if i lean the bike side to side it will either rev up or bog down and stall out. Could this be a plug wire or coil? Or does it sound like something else. Thanks for any help
i pulled the plugs today to take a look and the plugs on cylinders 1 and 2 were black and looked very carboned up. I checked on all the plugs by touching them on the cylinder head and they all seemed good, any suggestions?
Two were wet two appeared normal I believe. Cylinder 3 wasn't fully plugged In. Now I have replaced all 4 plugs and I know the wires are on proper.
Bike was bought used, and abused I guess you could say. It has a vance and Hines slip on exhaust, drilled airbox, and a dirty orange dry paper airfilter. Im going to have the carbs synced soon and possibly get it rejetter since I have no documentation as to what has been don.
