PROBLEMS - engine dies during acceleration - HELP PLEASE
Old Sep 11, 2006 | 08:26 PM
MaxKid84's Avatar
Default PROBLEMS - engine dies during acceleration - HELP PLEASE
Hey guys,
so lately when I accelerate briskly on the CBR the engine completely dies (and sometimes back fires) almost like I hit the kill switch. and it won't start back up for a few seconds after the oil light comes on. Sometimes I have to completely pull over to the shoulder to restart it.
Please I need help with this. I doesn't seem like a wiring problem because everything works at idle and low speeds, but once I rip on it she just dies after a couple seconds. Seems like something isn't balanced correctly or like the pistons get "stuck".
Lately I've been paying particular attention to letting the engine warm up before I take off. However the temp gauge never really gets all the way to the mid-range unless I'm in stop and go traffic for a long time.
any help would be appreicated. thanks!
Old Sep 11, 2006 | 09:02 PM
rrasco's Avatar
Default RE: PROBLEMS - engine dies during acceleration - HELP PLEASE
well, i would say it is a fuel issue. maybe running too rich since its backfiring? typically means too much fuel and the backfire is the excess getting burnt up in the exhaust.
Old Sep 11, 2006 | 10:30 PM
Kamakazi's Avatar
Yeah-- have to agree here. Everytime you are pulling on the throttle you are really just flooding the engine. You need to take a look at the carbs. Clean them, inspect the jets, and do a table sync. Check and make sure the air mixture is set correctly.
Old Sep 12, 2006 | 09:58 PM
MaxKid84's Avatar
Thanks guys,
makes sense since I think the choke cable doesn't fully disengauge so it's still on a little bit. That would def cause it to run rich. I didn't think that it would cause the engine to completely stop though, thats just crazy.
well
I wasn't planning on doing this stuff till the off season, but if this keeps up I'll have to take a day and just get it done.
Old Sep 13, 2006 | 11:30 AM
rrasco's Avatar
you have to realize that if the fuel/air mixture becomes too rich/lean you will lose combustion, hence your bike dying. fuel requires air to burn, if there is not enough air, it wont fire. kind of like putting a glass over a candle, the flame will go out once the oxygen is burned up. same concept.
Old Sep 13, 2006 | 04:05 PM
MaxKid84's Avatar
makes sense, I just never thought it would get to the point where the engine would just die.
Looks like I've got some more work for this weekend.
Ultimeas
Jul 29, 2012 11:10 PM
kyranger420
Sep 26, 2010 05:59 PM
SlickNic26
Sep 22, 2010 05:08 PM
snaggle213
Aug 21, 2009 05:05 PM
Shaken
Mar 31, 2006 11:16 PM
