Non start issue
Old Sep 25, 2012 | 10:10 PM
rayall01's Avatar
Default Non start issue
here's my problem. 88 600 starts just fine when cold. comes off choke almost immediately. runs like a champion. shut it off for a little while, and it will crank endlessly with no start. gets cooled down some, and starts fine. also, will sometimes start warm, and die in a minute or so. i'm thinking a weak fuel pump. any ideas, anyone?
Old Sep 26, 2012 | 12:04 AM
CorruptFile's Avatar
June 2013 ROTM
How are the carbs? First step is always to clean them. Make sure your mixture is adjusted properly. If that doesn't help, it could be intake boot leaks. Make sure your clamps between the carbs and engine are tight. Check for exhaust leaks too.
If that doesn't solve it, try a cold and hot compression test. Cold compression is usually a bit higher than hot. If your <100, then you could have warn rings. Checking valve clearances may be suspect too.
Sorry for the dumping of 1000000 ideas :P
graycbr
Apr 29, 2014 01:36 PM
Mr_Shamrock
Jan 8, 2012 02:11 PM
secretdestroyers
F2 Tech
Aug 28, 2011 10:17 PM
Ghostrider600
Sep 14, 2009 12:05 PM
thirty8ford
Feb 11, 2008 09:29 PM
