electrical issue won't start
Old Aug 17, 2011 | 11:50 AM
secretdestroyers's Avatar
Default electrical issue won't start
i got caught in a huge rain storm on a trip the other day, pulled off at a gas station and turned the bike off, now it wont start. battary has been charged and is in good working order. checked fuses (only 4 right) they are good. headlight fires up when i turn the key but nothing happens when i push the starter. no noise no clicking nothing. bike is in nuetral and side stand is up. any ideas?
Old Aug 17, 2011 | 12:41 PM
woo545's Avatar
There master fuse is right next to the battery. You need to check that one, too!
Old Aug 17, 2011 | 06:30 PM
thankes checked it, no luck however. also the battery is holding 12.94 volts
Old Aug 18, 2011 | 01:25 PM
woo545's Avatar
check the solenoid.
Spray contact cleaner on the starter switch.
Old Aug 23, 2011 | 12:10 PM
ended up being the solenoid relay.
Old Aug 23, 2011 | 12:23 PM
coldflood's Avatar
lol yep, let me guess you took the chain guard off right? Those things are notorious; wrap that thing in any chit you can find idc if its exhaust wrap or seran-wrap just get it covered
Old Aug 28, 2011 | 11:23 AM
yeah no chain guard here.
Old Aug 28, 2011 | 06:31 PM
so when i replace it with a new relay, for real what should i use to protect it from the elements?
Old Aug 28, 2011 | 09:25 PM
coldflood's Avatar
Pilot screws most likely, tighten all the way until they seat. Then 2 and 1/8 turn out on all four
Old Aug 28, 2011 | 10:17 PM
adrenalnjunky's Avatar
The answer is in here somewhere :-)
Is the moisture getting in the relay itself and corroding the internals? Qouls dipping in plasti-dip be possible? You can get that stuff at most places like lowes or home depot.
Plasti Dip Protective Coating Products | Plasti Dip Protective Coating Products | Rubber Dip Coating
NE1000F
Nov 16, 2018 09:00 PM
YourEnemy
F2 Tech
Sep 11, 2011 01:32 AM
titansuzi
Jun 18, 2010 08:53 PM
bogdan
Mar 3, 2009 08:23 PM
3dgar RR
Nov 5, 2008 05:20 PM
