No spark
No spark
I've got an 88 600F that I've be that I picked up from a friend who was neglecting it. It's got a whopping 100 miles on it and is pristine.
Last fall I rebuilt the carbs and got the bike running but did not get around to syncing them. So now I'm picking up where I left off and can't get the bike to fire. Somehow over the winter the fuel pump cut relay managed to fail as initially I could not get the fuel pump to run. I've temporarily jumper'd the relay connector so I can now the fuel pump runs and shuts off as it should when the float bowls are full. As far as I can tell I've got fuel but I have not pulled a plug to see if it wet. It sure smells like I have fuel getting to the CCs as the exhaust smells rich.
So, thinking I'm missing spark I've put a timing light on a plug wire and am not getting any pulses. I'm too lazy to actually pull a plug and check for spark. So assuming I really don't have spark does anyone know if jumpering the fuel cut relay somehow will inhibit the spark?
The way I understand the fuel cut relay is that it is supplied 12V on one of its three terminals. One of the terminals is connected to the spark unit and I believe the spark unit pulls this line to ground when it is firing the plugs. This causes the relay close and supplies power to the fuel pump.
I plan to order a new relay but wanted to get this thing running first. Any thoughts on how to proceed?
Ken
Ken
