low battery
Old Feb 15, 2006 | 01:34 PM
oliversta's Avatar
Default low battery
I tried to start my 1987 Honda CBR 600, I noticed that the ignition won't even start, and I'm just hearing clicking and the rpms rising on the tachometer. Headlights are dim, and you can barely hear the horn...
Question: Is it a low battery? and if so, is it ok to jump start it using a car battery?
Old Feb 15, 2006 | 02:58 PM
Tahoe SC's Avatar
Default RE: low battery
yes it is low...not a good idea to jump with car...better to push start.
some people end up ok from car, others blow all fuses and then some...
not worth it.
Old Feb 15, 2006 | 09:25 PM
dwhite645's Avatar
Don't jump it from a car. A typical car battery has a whole lot more amps than a bike battery does. Your best bet is to go to walmart or something and pick up a trickle charger that is good for cars, boats, bikes and ATV's. I bought a black & decker for like $40 and it worked great. Oh, and if you do get a trickle charger, when you hook it up to the battery, make sure you take off both + & - cables.
Old Feb 15, 2006 | 11:00 PM
cjbettis's Avatar
go to a auto parts store....I just bought one...similar issue...$25...automatic turn off...install plug so that always on battery just plug in when not ridding...way easy
and +2 on no car start bro
let me give you an analogy: you put a garden house in your mouth...fits fine...someone turns on water a little...no problems...still same fit, but they blast it...issues...same idea with volts and amps
Old Feb 15, 2006 | 11:13 PM
Tahoe SC's Avatar
awwwwrrrrhhhh....mawfaki....i can drink all the water you can pour immmaaa mouf!
Old Apr 10, 2006 | 12:48 AM
kustom98f3's Avatar
Just take the battery out and charge it. Problem solved.
estate4life
Dec 4, 2012 11:08 PM
jharbinson
Dec 31, 2009 09:23 AM
xander071584
Dec 24, 2008 01:45 PM
njdjh2o
Apr 11, 2008 07:20 PM
MDZ600F4i
Oct 18, 2006 07:50 PM
