Was fun while it lasted 😢
#55
So that little wheel 27 ) is the oil pump sprocket , that had come off, now I understand why my oil light came on so I think I will take out the clutch basket , but obv the engine seized whether it was starved of oil , something broke of and jammed or something is smashed up somewhere I think I’m just going to go threw the engine each part at a time and see if it’s possible to fix this one , if not I will salvage all the good bits for the other engine , I’m yet to take off the clutchside cover to look at the guts of that engine
#56
#57
It is really difficult to say as regards what damage has been done to the con rod and crankshaft bearings as a result of not having oil pressure.
If it was just for a short time, then they actually might be OK. A **** ton of rust in the cylinders in the other engine doesn't sound like good news.
It's going to be a difficult decision since whatever you decide, you're going to have to put the engine back in to test, and that's going to be a pain in the **** if you have to do it more than once. If you have had metal particles floating around, it's probably obvious but change the oil filter.
The following users liked this post:
Ed Harris (06-08-2024)
#60
