front forks bent
Old May 7, 2008 | 07:12 PM
borges99's Avatar
Default front forks bent
i have an 87 hurricane 600 front forks are definantly bent what can i do ?
also i can get a full set with the tripple tree and clamp ons from an f2 are they compatible to fit and work and also will the front fender fit if it works please let me know
Old May 7, 2008 | 07:23 PM
michigan_313's Avatar
Default RE: front forks bent
nothing on the frontend is interchangeble between f2 and f1. if you get f2 forks, you will need everything (rim, rotors, calipers, clamps, clips-ons, and fender).f2 rim is wider. f2 fork tubes are larger diameter. the only thing that will swap is the steering head bearings. the steering tube on the f2 will fit into the steering head of the f1, so if you get everything, you can do a direct swap. only things to look out for are steering stops, clip-on clearance, and possibly the key fob clearing the front fairing stay and being able to fully lock the steering.
Old May 11, 2008 | 07:47 PM
2bikes's Avatar
Hey I need the left fork slider if/when you find a new set for your ride. PM me or just post it here if you decide to sell your bent ones. Thanks.
Cbr_Guy322
Dec 17, 2011 04:16 PM
cbr600f3covina
Dec 5, 2008 05:14 AM
DBEAU
Jul 30, 2008 10:45 AM
x2old4aCBR600
Nov 15, 2006 08:55 AM
x2old4aCBR600
Nov 14, 2006 10:29 AM
