bent forks
Old Jul 28, 2008 | 02:23 PM
DBEAU's Avatar
Default bent forks
one or both of my forks are bent. how do i figure out which one it is?
Old Jul 28, 2008 | 02:24 PM
Aken's Avatar
July 2008 ROTM
Default RE: bent forks
Take them off and get them checked by a shop.
Old Jul 28, 2008 | 03:17 PM
Jaybird180's Avatar
You should be able to either check visually or check by looking for the one that binds when compressed.
A few shops can put them in a jig and measure and straighten if the runout is unsatisfactory. The proper way would be to remove the tube.
Old Jul 28, 2008 | 07:14 PM
DBEAU's Avatar
straighten them eh? that sounds a hell of alot cheaper than buying some... i'll check around
Old Jul 28, 2008 | 08:08 PM
rolandk's Avatar
Try measuringfrom the front axle to the rear axle on each side and compare.
Old Jul 28, 2008 | 11:21 PM
Jaybird180's Avatar
ORIGINAL: rolandk
You can get some of the alignment data that way, but what's to say that the problem isn't the rear or the headstock, or frame, or... you get my drift???
ORIGINAL: DBEAU
It's not that simple. Can't be always done and alot of places don't have the tools to do it properly. PLUS it weakens the material, and if not done right- You get a stress fracture right when you're hard on the brakes orup on a stoppie.
Old Jul 29, 2008 | 12:51 AM
adidas00's Avatar
Remove the tubes and roll them on a window glass, becauze the window glass is perfectly straight. My advice is to buy new tubes and a new triple tree.
Old Jul 29, 2008 | 07:54 AM
Jaybird180's Avatar
ORIGINAL: adidas00
If you're going to spring for new tubes, you may as well contact a suspension shop and offer to buy whatever they have.
Old Jul 29, 2008 | 09:39 AM
DBEAU's Avatar
Honestly, its off so little that i'm just gonna try and ignore it for as long as i can... It doesn't pull and there are no noticable driving issues because of it.
Old Jul 29, 2008 | 09:40 AM
DBEAU's Avatar
...this is really getting annoying... The only noticable problems are the tires wears a little more on one side than the other and the handlebars look slighlty off.
