bent forks????
Old Dec 4, 2008 | 10:34 PM
cbr600f3covina's Avatar
Default bent forks????
how do i check to see if my forks are bent? i mean im almost positive they are because i have gone through 2 sets of front wheel bearings in the last 6 months and only one side goes bad?
Old Dec 5, 2008 | 05:14 AM
pacemaker's Avatar
Default RE: bent forks????
How long have you had the bike & have you done anything that would have caused bent forks?
Usually bent forks translates through to the handling, but not always & often wot you suspect as being bent forks is just a matter of loosening the triple clamps, which can help the forks realign.
Often its impossible to tell if your forks a out of whack, even when their off the bike (unless their well & truly bent) & you may need them to be looked at by the shop.
I was told by a mechanic that the F2's & F3's can have a problem with the front bearings, but at the rate your going through them, something is definitely wrong.
Micscience
Apr 6, 2010 08:55 AM
DBEAU
Aug 3, 2009 02:44 PM
cbr600f3covina
Dec 4, 2008 11:12 PM
DBEAU
Jul 30, 2008 10:45 AM
cbr600f3covina
May 25, 2008 12:54 PM
