CCT Issues
Old May 29, 2011 | 04:43 PM
tds94probe's Avatar
Default CCT Issues
So, I go to clean my carbs and decide ill pull out the cam chain adjuster and replace it. Carbs out, and I notice a little black plug with RTV sealant on it where the cam chain tensioner should be bolted from the inside.........interesting. Pry the plug out with a screwdriver (which turned out to be one of the black clips used for holding door panels to cars) and remove my Adjuster..........What do I see behind my adjuster? The Steel Portion of the Cam Chain Tensioner that the stud is attached to! Assuming the previous owner sheared off the stud when tightening it at some point and just plugged the hole. Luckily the tensioner hadnt popped off of the cam chain, but needs to be replaced due to the sheared stud, as well the film thats on the side that guides the cam chain is worn through, so time to order one tomorrow. This could have been catastrophic!
Old May 30, 2011 | 07:31 PM
tds94probe's Avatar
Well just ordered my new CCT off of bikebandit, 119 shipped to canada. Would have been cheaper at the dealer but they wouldnt have it in until july 8th. TOOOO LONG!
Old Jun 15, 2011 | 11:20 PM
tds94probe's Avatar
New CCT is installed, just need to pick up some gasket material to make a gasket for the new adjuster. Annnnnnnnnd retorque the cam journals, annnnnnnnnnnnnnnnnnnnnnnnd reset my intake valves.
mooseboy
May 21, 2011 03:11 PM
ddavis17
May 21, 2011 11:51 AM
SparkeeVR4F4i
May 13, 2011 04:06 PM
mk4
Apr 3, 2011 12:22 AM
05CBR600F4i
Feb 6, 2011 08:40 PM
