CBR600FL starting problems
Old 10-16-2009, 04:51 AM
skarrs's Avatar
Default CBR600FL starting problems
Hi,
I was using the bike uptill last week, then after a heavy downpour the bike will no longer start with the electric start. works fine if I bump start the bike.
The bike does turn over ok, There is no spark at any cyclinder. the coils are getting the same battery voltage. When trying the coils using a Ohms tester I get one peak in the initial turn over, but that was all, same on all 4 cyclinders (not hundred percent sure I am using the ohms tester right though). The run switch is working fine.
I was told to test the ECM using the 6 pin green wire and I think it was yellow/blue and green/black cables these showed normal voltage.
Any other sugestions?
Old 10-17-2009, 01:34 AM
KongBastard's Avatar
Check your engine run switch on your handlebars.
KongBastard
Old 10-17-2009, 05:11 AM
skarrs's Avatar
forgot to mention I've checked that already and works fine, what I cant get my head around is it wont start with start button but yet you can bump start it.
Also it lists there is suppose to be a 10A fuse, I have searched everywhere on the bike and can't find one. the bike is a FL model but the year was 1991. So not sure if there was a modification done and it was combines into the main fuse.
Old 10-18-2009, 04:36 AM
Check your battery voltage (if you haven't already). You can also try jump starting it from a car, which would take the battery voltage level totally out of the equation.
Sometimes the run switch and /or start switch cause an issue where it will turn the bike over but it will not start.
KongBastard
Old 10-18-2009, 04:44 AM
Should have added to check the sidestand switch and the ignitions switch (although I think that is doubtful)
KongBastard
tomtom
10-07-2011 10:26 AM
Stan_Laurel
10-23-2008 10:29 PM
Blodgettboy24
01-31-2008 09:42 PM
bikerinlove
01-31-2008 01:33 PM
skaraider
01-20-2008 07:52 PM
Quick Reply: CBR600FL starting problems
