Cbr f1 87 running problem
Old 09-07-2013, 02:09 PM
dodger79's Avatar
Hi mate
There are guys on here who can give better advice than me but I would be tempted to: take it for a run and get the bike to make the same issue. Then take a roadside reading of the temperature (using a cheap infrared thermometer) of each exhaust header at the start of the first bend. The coolest header might indicate the carb/cylinder that isn't supplying the most fuel/working as hard. Then back at home check that carb thoroughly for cleanliness: jets, float height, needle valve condition, diaphragm and so on. Also you might check the ignition system for that cylinder.
Just an idea or two, like I say others on here will advise you better.
Hope you find a solution and if you do let us all know.
Safe riding
Roger
Old 09-07-2013, 09:44 PM
kidkcusu's Avatar
Registered Users
Whoever you are dodger79 is .... Your reply to his question was the most respective and informative response I've ever seen on any forum
Old 09-08-2013, 10:06 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Keep in mind the interior cylinders tend to run a bit warmer so a small temp swing with outer pipes cooler is normal. If your carb drops out altogether you'll get a substantially cooler pipe but if the carb just has restricted flow it can actually run much hotter. A lean condition can run very hot.
Old 09-08-2013, 11:52 AM
dodger79's Avatar
That's good thinking chainstretcher about a lean air fuel mix making a cylinder run hotter. Something I don't know but would like to - if you have our bike with everything working correctly, how much hotter the middle cylinders are at optimum running temp compared to the outer ones?
Old 09-08-2013, 12:13 PM
In the shop sitting still my interior cylinders on a water cooled engine ran 30-40F hotter ... air cooled (Katana 750) ran closer to 50F hotter. Never took a measurement out on the road with air flow at speed cooling everything. Turbo Busa's manifold would be a dull cherry red at night after a spirited ride
citroenexpert1
01-29-2013 11:12 AM
low4door
06-17-2009 05:11 PM
flipkid
09-23-2008 07:10 AM
Talos
06-27-2006 04:58 AM
johnwoods23
06-22-2005 04:55 PM
Quick Reply: Cbr f1 87 running problem
