Brake fluid leak please help
Old Nov 29, 2010 | 06:44 PM
boostdog's Avatar
Default Brake fluid leak please help
Ok so I'm leaking fluid from what I can tell is the dist block right in front of the radiator. Forgive me if I'm calling it the wrong thing. But I have fluid running down the right side front fork above the fender. Any idea where to get a replacement? I'm unable to find it on eBay or google
Old Nov 30, 2010 | 07:54 PM
tds94probe's Avatar
Scrap Yard, or BikeBandit.com
Old Dec 1, 2010 | 01:05 PM
tripicana's Avatar
have you tried tightening the bolts?
Old Dec 1, 2010 | 01:24 PM
boostdog's Avatar
i haven't as the bike is over at my parents but i will tonight when i go and pick it up. what is this piece called anyway? from what i can tell it looks like a dist block.
Old Dec 1, 2010 | 01:47 PM
tripicana's Avatar
microfiche calls it a joint. try tightening the bolts at the brake lines. it seams unlikely the joint itself is leaking, either something wrong with the connection at the fittings, or brake lines themselves
http://hondaparts-direct.com/fiche_s...1987&fveh=3036
Old Dec 3, 2010 | 12:44 PM
boostdog's Avatar
well it's not leaking brake fluid the forks are actually leaking so a rebuild will be next. thank you for you advice though..
MuscleswitCBR
Feb 19, 2011 09:58 PM
jlaretto
Sep 3, 2008 09:08 PM
Jayced1
Sep 17, 2007 08:39 PM
Jayced1
Aug 11, 2007 02:00 PM
ryanfeldman
May 8, 2007 11:17 PM
