Best sprocket gearing?
I'm converting to a 520 chain and am getting custom sprockets and i was wondering what the optimum gearing was, I will be doing some interstate driving but mostly in town. Optimum on the site where im getting them is 15 front and 47 rear, Anyone have this combo? If so how is it or if you have anything else any input would be great. Thanks.
Guest
Posts: n/a
i think thats the combo i have i went down one tooth in the front and up 2 teeth in the rear with the 520 chain. its a vortex kit. i really like the set up there is a great difference in the acceleration and its easier to wheelie lol. the top end isnt affected that bad. i dont do over 75 mph on the highway usually but there is plenty left if i want to lol
what all is involved with the swap ?
thanks
-Lee
1 down in the front is the equivalent of up 3 in the rear. On most bikes -1, +2 is the best gear ratio. The 520 is the width of the chain and sprockets. Stock is a 530 usually. I've found over the years unless you're at the track and need oz. of a difference in weight, go with steel gears. -1, +1 I got my fastest time at the track with a 10.6 stock 929rr. When I went -1, +2 I couldn't break 11.
both are pretty easy to change, loosen chain, unbolt sproket, replace, and torque bolts. for the rear sproket you have to remove the tire.
bowtieboy42
F2 Tech
07-10-2012 03:53 PM
NoBrains01
03-06-2010 09:56 AM
kreush33
05-21-2006 12:28 AM
