axle diameter?
Old Oct 21, 2008 | 02:37 AM
Hurricane rider's Avatar
Default axle diameter?
can someone tell me the diameter of our bike's rear axle in mm? I have an idea for a rear wheel swap that has been done on another bike, and may well bolt right up to our Hurricanes allowing a 160 rear tire with a different brake caliper and bracket installed.
If it will bolt up, I'll post up details and possibly begin offering a conversion kit to help you guys get wider rear wheels without changing to a bigger swingarm.
Old Oct 21, 2008 | 02:59 AM
Gearloose's Avatar
Default RE: axle diameter?
17mm, maybe plus or minus some very small amounts for clearance/manufacturing tolerance.
Old Oct 21, 2008 | 12:40 PM
Awesome. thanks. I was looking at an idea that the Suzuki GS500 crowd uses with a newer Katana 600/750 rear rim, which is a 4.5" rim and from what I'm seeing it looks as though it will bolt right up no problem. the caliper bracket and katana caliper appear to be a necessary part along with spacers, but I'm fairly sure with the appropriate measurements you could have spacers fabbed up.
lowcel
Jan 12, 2014 07:47 AM
nieldw
May 10, 2012 09:14 AM
lloydiecbr
Apr 14, 2011 05:53 PM
daazndood
Feb 27, 2009 12:00 PM
Aweasel
Feb 17, 2009 08:33 AM
