1987 Hurricane to 2003 CBR600RR Conversion
Old Mar 27, 2014 | 08:33 PM
  #171
reaper101's Avatar
Ah ok yea those are included in the pieces I'm buying as the whole set, ok so I should order that harness? Couldn't find another afraid it might go away, yea I called a honda shop and they ordered me the fairing bolt set, did u have to order your headlight bulbs? If u did from who? So amped to get started to bad I work two jobs
Old Mar 30, 2014 | 08:01 PM
  #172
reaper101's Avatar
Do u think it would be possible to get the exhaust to go underneath the tail?
Old Mar 31, 2014 | 06:54 AM
  #173
dennisgb's Avatar
Anything is possible but there is a point where you might as well go buy an RR. Remember the RR was designed with the exhaust under the tail. To do it right you would need to install the RR sub frame. Even then the frame and components on the Hurricane may get in the way of the pipe coming up to the tail. It would take some major modifications to make it work.
I'm bringing the exhaust up to just below the tail along the side. That is the easiest way to get a better look and doesn't take a huge amount of mods, just a special exhaust and piping. I'm also using a smaller can so it can tuck in.
Old Apr 10, 2014 | 04:37 PM
  #174
reaper101's Avatar
Hey Dennis would u by chance have a picture of what the headlight wires would look like? My wires came in and I tried to plug in the bulbs but they would t fit?? Need to send it back before they won't accept the return on eBay tks in advance
Old Apr 10, 2014 | 08:32 PM
  #175
dennisgb's Avatar
Not sure what the question is. If you have the RR harness and plugs everything should work in the RR headlight assembly. The RR harness then gets spliced into the Hurricane wires. I don't have a picture because I haven't done this wiring yet but t's pretty straight forward. Do you have all the RR components? Headlight assembly?
Old Apr 11, 2014 | 07:06 AM
  #176
PSonic's Avatar
you need convert h4 to RR wiring, is simple. See if my files can help you
i used in my Civic when I put AngelEyes (h4 -> h1/h7)
https://drive.google.com/file/d/0B9w...it?usp=sharing
Old Apr 12, 2014 | 10:53 AM
  #177
reaper101's Avatar
yes i bought the wiring from it, bought the two bulbs and i have all pieces to do conversion but there is no socket that i see to plug the bulbs into the harness? even the ones that do seem to be they don't fit in? i currently modified my original bulb to fit into the assembly till i figure where i went wrong ty for ur input heres pics to provide where I'm at
Old Apr 12, 2014 | 11:00 AM
  #178
reaper101's Avatar
as u can see the bulbs don't fit in? maybe I'm trying the wrong spots but that seems to be the most logical spots and there two of those... so two plugs two bulbs?? yet neither fit? wrong wire or wrong bulb? lost at this point and I'm just in a rush too see if i need to send this wire back
Old Apr 12, 2014 | 11:03 AM
  #179
reaper101's Avatar
[IMG][/IMG]
Old Apr 12, 2014 | 11:12 AM
  #180
reaper101's Avatar
idk whats happening but if u click the image above it will show image deleted or what not if u just click next thats the image I'm trying to post, the bulb goin into the socket ty all
