'00 CBR600 carb problem, need help
Old Sep 19, 2013 | 07:24 PM
Taylor Robinson's Avatar
Default '00 CBR600 carb problem, need help
I recently bought a CBR 600, it runs great from idle to around 8k rpm, it has a Yoshi rs-3 pipe on it so I figured the previous owner didn't have the carbs jetted. I want to re-jet my carbs but I don't know what jet/needle set would work best with my setup. i don't want to take it to a shop so they can charge me for something i can do on my own with some help with info.Anyone have any advice on what set I need? Thanks in advance.
Old Sep 19, 2013 | 09:28 PM
TahoeRider's Avatar
You will probably have better luck in the F4 section, but I would not start changing the jetting sizes before pulling & thoroughly cleaning the carbs and checking the jets & needles while you have them apart. It's more likely a dirty or clogged main jet, or other fuel delivery problem rather than a jet size issue.
If the only modification to the bike is the exhaust it should run fine on stock main jets, or at most 1 to 2 sizes larger depending on your altitude. Clean the carbs, check the jet sizes, check or replace the fuel filter, and make sure the pump is working correctly first.
Old Sep 19, 2013 | 09:43 PM
cBrentb's Avatar
Yeah do all that stuff first then after that pull the plugs. Sooty black= running rich, whiteish ashy looking=running lean, paper brown tanish color= just right. I had a k&n filter with yoshi rs3 and it ran perfect without any jet size changes.
Old Sep 19, 2013 | 09:47 PM
cBrentb's Avatar
Oh, also check for a clogged fuel filter. Run it without a fuel filter for couple miles to see if it opens it up and runs any better. Its happened to me before.
hardhat_harry
Dec 21, 2008 07:04 PM
ta8218
Jun 23, 2008 10:29 PM
Heffer2586
Apr 16, 2008 09:39 PM
Trips
Nov 26, 2006 01:45 AM
jrizzno40
Jul 25, 2006 04:59 PM
