Oxford Heated Grips
If you plan on having a few axillary devices, the best way is to make a secondary fuse box.
Using an automotive relay, getting power directly from the battery, and being toggled on/off by the license plate light (key switched source of power). This way, when you turn the key off ALL of you aux. devices will turn off. No risk to flatten the battery by forgetting to turn your grips off.
If this is interesting I've got several diagrams on this topic... most of which are in the ninja 250 FAQ.
Here it the FAQ Article:
http://faq.ninja250.org/wiki/Install...ssory_fuse_box
I personally recommend the license plate light, because in the event that something goes wrong - all you lose is that light. Many people tap the horn circuit, but I really would rather have my horn, than my aux devices.
http://faq.ninja250.org/images/4/4d/722202.gif
Hope that helps.
Hope that helps.
