CBR 1100XX "Super Blackbird" 1998 - 2003 CBR 1000XX
Low mileage CBR resurrection s
Old Jan 28, 2018 | 08:56 PM
big smoooth60's Avatar
Default Low mileage CBR resurrection s
Does anyone here have any experience with resurrecting a CBR with low mileage back from the dead? I'm looking for what parts, hoses, seals etc to keep an eye on. This is a bike with a Two Brothers exhaust the one that has two cans stacked on top of the other. The bike does start and sounds like it runs on all four cylinders but is reluctant to start and if the throat is twist there is a bit of black smoke when cold..
Old Jan 28, 2018 | 09:54 PM
Sprock's Avatar
I have not brought back a blackbird at least not yet ! but have several older CBR's and two VF 1000 interceptors that I have done - I'd be eyeballing the usual - fork seals
brake lines and seals (I'd do right away as a matter of safety along with new rubber
then just run some techron or any kind of fuel injector cleaner through her and see whereshe's @ depending on exhaust condition maybe need some header work and of course new hoses for cooling and maybe valve cover gasket if hardened up
My 2c's
Good luck with it, sounds positive seeing as how it's firing on all 4
Old Jan 29, 2018 | 07:25 AM
My 2c's
02cents. Thank you for the reply. W I hadn't thought about the valve cover gaskets but it does make sense. Given the age of these bikes has there been instances of the brakelines expanding?
Old Feb 1, 2018 | 10:27 AM
TimBucTwo's Avatar
I wouldn't think so unless you see some cracking. If you are worried, maybe go with SS lines.
HEL has them for the price of your first born. WOW!!!!
Old Feb 3, 2018 | 02:40 PM
Ok I got the bike home. It needs a good cleaning and the fuel cap needs replaced as the previous owner had drilled out the lock. There are also some missing fairing bolts. I took the bike for a spin around the block and it is powerful!
LARRYTHEPIRATE
Nov 12, 2017 06:55 AM
SM8898
Apr 14, 2017 06:23 PM
daught
Oct 9, 2012 09:19 PM
forced1(nyc)
Aug 21, 2009 02:40 PM
ColdAudio
Feb 8, 2007 03:52 PM
