WONT START!! 05 CBR1000RR
Old 05-22-2008, 02:03 PM
BigCountryBllr's Avatar
Default WONT START!! 05 CBR1000RR
I have a brand new battery its not the problem..
My nephew played with the idle adjuster. Not sure what way her turned it or how many times.
My headlights work, horn, etc. Just wontGO when i hit engine start..
ANY IDEAS?
Old 05-22-2008, 02:10 PM
WhiteKnite's Avatar
June 2009 ROTM
Default RE: WONT START!! 05 CBR1000RR
Does itturn over or nothing at all? Theres a 1001 reasons this could happen so the more info the better.
Old 05-22-2008, 07:06 PM
mininsx's Avatar
Check the kill switch first, then see if he screwed around with the kickstand switch somehow. If he only screwed with the idle it should still start.
Old 05-22-2008, 07:43 PM
SD2007's Avatar
In addition to the above, make sure the transmission is in neutral and also pull in the clutch just for good measure.
Old 05-22-2008, 09:20 PM
justasquid's Avatar
Like already stated, If it wont turn over, it is probably the kickstand switch.. put the bike in neutral and try again.
if it turns over, it could be just the killswitch is in the off position. Also, If your not sure about the adjuster,give the throttle a slight amount of gas and turn it over. Very slight amount is all that is needed. If it fires up, then turn your adjuster clockwise to increase the rpms.
Like said already again, the more info you can give, the better.
C Jacob W
07-29-2013 11:03 AM
CTcbr929
07-31-2009 12:25 PM
tagger609
06-27-2008 02:09 PM
BigCountryBllr
05-22-2008 10:47 PM
mishab
09-07-2007 01:00 AM
Quick Reply: WONT START!! 05 CBR1000RR
