WONT START!! 05 CBR1000RR
I have a brand new battery its not the problem..
My nephew played with the idle adjuster. Not sure what way her turned it or how many times.
My headlights work, horn, etc. Just wontGO when i hit engine start..
ANY IDEAS?
ANY IDEAS?
Like already stated, If it wont turn over, it is probably the kickstand switch.. put the bike in neutral and try again.
if it turns over, it could be just the killswitch is in the off position. Also, If your not sure about the adjuster,give the throttle a slight amount of gas and turn it over. Very slight amount is all that is needed. If it fires up, then turn your adjuster clockwise to increase the rpms.
Like said already again, the more info you can give, the better.
C Jacob W
Jul 29, 2013 11:03 AM
