A question about brakeing
Old Dec 18, 2011 | 06:50 PM
rustynail17's Avatar
Question A question about brakeing
ok...so i got in a wreck about a month ago just now almost over it....my front brake lever is broke however, that's not the problem....when i got back on my bike for the first time...it would pull and not hold at all...after pumping it for a while it started to harden up but its still not fully working, how can i fix this? and it has brand new brake fluid.
Old Dec 18, 2011 | 06:58 PM
MadHattr059's Avatar
You have air in the lines, most likely. Air compresses, brake fluid doesn't, thus spongy brakes. There are a couple of good pictorals on bleeding the air from the system on this forum. Search in the 'how-to' and general tech forums.
Hope this helps, Ern
Old Dec 18, 2011 | 07:08 PM
wagzhp's Avatar
Yep sounds like air in the system, or the master cylinder got damaged. Try bleeding first.
Old Dec 18, 2011 | 07:31 PM
Thanks yall, and nothing was damaged but plastics how the hell would a wreck make air in the lines though...and can you use car brake fluid in a bike or does it have to be special brake fluid
Old Dec 18, 2011 | 08:18 PM
wagzhp's Avatar
Automotive brake fluid is what is used in bikes too. (Not sure if it's DOT 4 or 5 though.)
Old Dec 19, 2011 | 07:40 AM
jeffjones's Avatar
It most likely wasn't the crash that got the air in the lines but on the repair. You said you get a new brake line? Whoever installed that probably didn't bleed the system properly
Old Dec 19, 2011 | 06:24 PM
If the bike lays on it's side, air can get past the diaphram on the master cylinder and into the lines.
Ern
Old Dec 23, 2011 | 03:08 PM
Ern
after time of using it, it fixed its self, works now...bought a new brake lever for a ridiculous price...50$ waiting for that to come in...fml anyways...
thanks for answers guys!
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
