PROBLEM! PLEASE HELP!!!
HEY EVERYONE, IM NEW TO THE SITE, I JUST RECENTLY SWITCHED OVER FROM A GSXR TO A CBR, I CURRENTLY HAVE A 07 CBR1000RR WITH A YOSHI EXHAUST.K&N,PCIII,AND A CUSTOM DYNO TUNE. BUT I HAVE A PROBLEM NOW, I HAVE PUT OVER 1500 MILES ON THE BIKE WITH THESE MODS WITHOUT A PROBLEM AND I WAS RIDING TODAY AS NORMAL WITH NO PROBLEMS AND WHILE CRUISING IN 6TH GEAR THE BIKE STARTED BURBLING LIKE IT WAS CHOKING AND THE F1 LIGHT CAME ON AND KILLED THE BIKE IMMEDIATLY, IT WOULDNT START SO ITURNED THE KEY OFF AND ON AND THE LIGHT WENT AWAY AND ANY TIME AFTER THAT EVERY TIME I WOULD NOT BE GIVING IT HEAVY THROTTLE THE BIKE WOULD BURBLE THROW THE LIGHT AND IMMEDIATLY DIE AGAIN! ANYONE KNOW WHAT MAY CAUSE THIS ISSUE! THANKS!!!
Guest
Posts: n/a
Well I think it is caused by the CAPS LOCK KEY
Hiyu and Welcome to the CBRForum mate ...
Your problem is more for the 1000RR guys so I will let them answer you , which should not be too long ..
have fun and good luck with your problem ..
open the gas cap if you hear a presure release then you have a vapor lock symptom ... (from doing your filters and the fuel likes/vent lines)
also BTW get rid of the KN's they SUCK on 1000's i have 6 1000's in my garage and i can tell you BMC race are the best for these bikes
The K&N works fine on my bike. It was dyno tuned with the Power Commander and 2 Bros exhaust. The problem with race filters is that they let in a little more dirt so the motor won't wear as well as those with more filtering over the long haul.
dewthedoo05
Sep 4, 2007 09:32 PM
