New blinkers
Old Dec 29, 2014 | 05:22 PM
dad0507's Avatar
Default New blinkers
I purchased my 05 1000rr with no rear signals or the front aftermarket signals not wired up. I wired up the rear signals pretty easy. The front have 3 wires from the harness and only 2 from the signal. How do I wire these in? Also when I use the turn signal it does nothing. It doesn't blink at the light or on the dash. And finally the bright light does not work either. Any help is much appreciated. Thanks.
Old Dec 29, 2014 | 06:16 PM
dad0507's Avatar
Ok so I figured out the wiring for the front signals but the bright headlight and the signals still don't work.
Old Dec 30, 2014 | 07:55 AM
Conrice's Avatar
The 3 wires account for a running light and turn signal, but it sounds like the issue lies with in the entire switch on the left bar.
Does the horn work? Id check to make sure the connector has a good connection.
Old Dec 31, 2014 | 11:25 AM
dad0507's Avatar
So the horn works. The bright light has a loose connection. If I press it down with a little pressure it turns on. Do you think the blinkers are related to this? Again there is zero response to any of the light indicators on the dash.
Old Dec 31, 2014 | 01:34 PM
Conrice's Avatar
Yes, because you're not getting anything on the dash and you had issues with the brights. Also, check your fuse.
Then I'd test the relay if everything else checks out.
sunny
Feb 23, 2011 11:30 AM
shrtbus
Nov 29, 2008 02:21 PM
FosmoenAlex
May 2, 2008 10:15 PM
Slipspace
Jul 28, 2006 08:42 PM
