Need help with 09 charging issue
Old Nov 3, 2010 | 05:54 PM
bigbob65's Avatar
Default Need help with 09 charging issue
Well, Im tring to find the procedure to testing the Rectifier.
Battery is good, Stator looked ok when I replaced the side cover ( bought the bike as a wrecked unit.)
BIke will start and run. And when I check the battery the voltage will go up and down with the bike rpm but slowly gets lower and lower.
If I disconnect the battery while the bike is running, it will run for 3 seconds or so then dead.
Any help is appreciated.
Old Nov 3, 2010 | 08:07 PM
thrasher572's Avatar
Disconnecting the battery while the bike is running will blow the shyte out of the rectifier. If it wasn't pooched before it will be now. That is a big no no. I'd order an new rectifier right away.
When you remove the battery from the circuit you cause a voltage spike. The spike will find a path to chassis ground...usually by shorting out a diode on the rectifier. The symptoms of gradually loosing voltage in the battery are consistant with a bad diode. Hopefully the insulation on the stator was strong enough to withstand the spike.
If these bikes ran a generator disconnecting the battery would not cause the bike to stall, but it is an alternator.
David Van Onselen
Oct 6, 2013 02:03 PM
cklein85
May 26, 2013 07:22 PM
uptoodamlate
Nov 29, 2009 06:13 PM
ckxtreme
Jul 24, 2009 02:03 PM
iconfever
Jun 3, 2008 10:39 AM
