Gear problems ?
Old Jun 1, 2009 | 08:04 AM
Will1000RR's Avatar
Default Gear problems ?
Just curious, has any '08 1K owners ever have any gear/clutch problems? any difficulty with rpm struggling to reach higher rpm's? before or after the recall issue? Thanks.
Old Jun 3, 2009 | 08:20 AM
Will1000RR's Avatar
Default For those who might have the same issue as mine ...
I took mine about two month ago as per VIN # it needed the clutch changed. Weeks later, BAM!! problems with bike struggling to pass 8k rpm, gears were slipping and didnt feel as it did when I bought the bike. Yep !! Took it back.
Dealer didnt charge me a penny the second time around because I gave them the third degree for the error they made. The issue was-the mechanic at dealer install the entire piece which by the way is assembled together however there are two springs that, if not alligned properly, can later on with hitting the throttle, eventually start slipping causing the lose of power and slipping of the gear hence the problem I had with rpm struggling to even get past 8k rpm. Well, the head mechanic explained and show me the springs and assured me it was alligned as it should be. Man, I rode the bike back home and OMG !!! dude this bike know if definitely is a BEAST ! It's pulling as it did before the issues and I completely am satisfied.
lap9387
Dec 21, 2011 11:17 AM
Dweebster
May 6, 2011 12:03 PM
dirtdobberoffroad
Sep 8, 2009 09:27 PM
2004f4iguy
Jul 23, 2009 08:12 AM
bhoffman11
Nov 4, 2007 10:49 AM
