CBR1000RR Repsol on runs in Nutural??? Help
My CBR1000RR Repsol has me in tears this spring.
The bike was running fine, then on friday last week i was on the highway and she acted like someone shut her fuel off and we rolled to an almost instant stop???
Nowshe only runs in Nutural??? The bike will start in N andpurr no matter how high i rev her,butonce i lift the kick stand and kick her into first she continues to run smoothly for 10 - 30 seconds and then shuts down abruptly! The electricskeep working but it seems there is no fuel or spark or someting. I can only start her by putting it back into N, turning the ignition off then on - then she'll start right up???
Varous kick-stand tests lead me to beleive that the kick-stand switch is not the problem.
its under warranty but the bike shops around Providence are 6 weeks out right now.
Any ideas?
Your help would be greatly appriciated
Any ideas?
Any ideas?
Any ideas?
Hi Paul,
I think you will find that the problem is a faulty neutral switch, this is located at the rear of the cases, sitting on the bike it is the right hand side. I had the same problem with mine with .8k's on it, lucky for me I work for a Honda dealer and switched it with a new one and problem solved.
Hope this helps.
Hope this helps.
