Broken (stuck) Lower Adjusting Bolt
Old Mar 15, 2014 | 12:07 PM
TrickyNic's Avatar
Exclamation Broken (stuck) Lower Adjusting Bolt
So in my rather pathetic attempt at trying to drop the engine (wanting to only do this by 1" or so to remove the water joint) I managed to break off one of the two pegs on the Lower Adjusting Bolt the Upper one came out fine (well not all the way but enough to free the spacer).
My guess it is suffering from corrosion, I tried wedging a screwdriver end in the gap to close up the gap when trying to undo it but to no avail. I guess the only way to get this out is to use a large extractor (tap and die) or is there anything else, any ideas suggestions would be most welcome. Just to top it off I can not get the castle nut to thread back on
If I can not remove this is there likely to be some kind of vibration, chatter?
https://cbrforum.com/forum/attachmen...1&d=1394902731
https://cbrforum.com/forum/attachmen...1&d=1394902697
Attached Thumbnails Broken (stuck) Lower Adjusting Bolt-cbr1000rr-frame.jpg   Broken (stuck) Lower Adjusting Bolt-img_2533.jpg
spdbump36
Aug 1, 2019 12:08 AM
willklee
May 23, 2011 02:59 PM
black_98civic
Dec 15, 2008 09:53 PM
02f4iguy
Aug 29, 2006 02:41 PM
patas75
Feb 13, 2006 04:56 PM
