beyond pissed
Old Apr 14, 2011 | 03:20 PM
geturleanon's Avatar
Default beyond pissed
I have a 2006 CBR !000. Sat on a tender during the off season, started up right away....but as soon as I put it in 1st gear it shuts off as if the kickstand is down. It seems like the clutch isn't engaging but I dont know why.......any suggestions on how to fix this problem?
Old Apr 14, 2011 | 03:40 PM
jeffjones's Avatar
Did you check your kickstand sensor?
Old Apr 14, 2011 | 04:14 PM
PlayfulGod's Avatar
ummm try it with the kickstand up
Old Apr 14, 2011 | 08:40 PM
dray0n's Avatar
He said as if the kickstand is down.
Check the sensor as suggested first. It's the easiest first step. You can also complete the circuit of the kickstand to test if it is the issue.
The clutch may be frozen as well. Try rolling the bike forward at a few miles per hour N put it into gear. If it goes into gear and still runs your clutch plates are frozen.
Old Apr 15, 2011 | 05:30 PM
i see reading and comprehenssion isnt one of your strengths....but thanks
Old Apr 15, 2011 | 05:33 PM
That didnt work, so its in the shop now.....thanks for your suggestion
Old Apr 15, 2011 | 08:40 PM
dray0n's Avatar
Sorry bro. Hope it's cheap and easy.
Old Apr 15, 2011 | 11:51 PM
bluebeltbuckel's Avatar
That sucks but hopefully it will be a cheap fix good luck with it
Kuroshio
Jan 10, 2012 02:15 PM
canhead64
May 6, 2010 11:00 PM
zoomman113
Jan 4, 2010 12:50 PM
jpanside@gmail.com
Jun 5, 2009 09:57 AM
SchiraF4I
Apr 14, 2007 04:52 PM
