2008 rebuild question
Old Oct 25, 2023 | 06:28 AM
cdek's Avatar
Default 2008 rebuild question
Buddy heard chattering from his gearbox, we dropped the oil pan and found gear teeth laying in it. We split the case and took the gears out and found this:
Gear from the main shaft
Gear from the counter shaft
Ordered what was needed.
But now an old timer at work says "it's not worth it since the trans blew and it being a shared oil system." Which makes sense, but if everything is inspected and looks good, I don't see any harm in it. Thoughts?
Old Oct 25, 2023 | 08:12 PM
tona955's Avatar
The old timer is correct I suppose. The broken teeth that you found in the oil were they intact or mashed up? can you account for all missing metal work. If the case is already split you could try blowing out all the oil channels and see if you discover more bits, would be a shame to condemn the complete engine and the cost associated with that.
131commando
Nov 7, 2021 08:22 PM
jorian
Oct 24, 2011 09:29 AM
horse_power777
Apr 5, 2011 05:13 PM
MuscleswitCBR
Mar 29, 2011 10:20 PM
bladerep
Jun 3, 2008 10:54 AM
