08 won't start
Old Sep 1, 2008 | 03:44 AM
blkmrkt_lung's Avatar
Default 08 won't start
I recently laid my bike down pretty hard. Tried starting it, the kill switch is off, it in neutral, I can hear the pump, there is presure and the smell of gas coming from the exhaust and it cranks, but doesn't start. Any idea, anyone.... sparkplugs?
Old Sep 1, 2008 | 08:27 AM
GBracer's Avatar
Default RE: 08 won't start
Its an 08! Its under warranty, bring it to the dealer!
Old Sep 1, 2008 | 01:30 PM
even after i crash my bike?
Old Sep 1, 2008 | 05:47 PM
GBracer's Avatar
How bad is it wrecked? Is it drivable otherwise?
Old Sep 1, 2008 | 07:40 PM
no i crashed it going 80... had to replace every peice of body work, subframe, cowl stay, break lines foot pegs shifter levers handlebar power commander.... so ya it was pretty damaged... as far as the internals everything is in great shape.. as far as from me looking at it... so could it be my spark plugs or sumtin?
Old Sep 2, 2008 | 01:49 AM
lilium's Avatar
ORIGINAL: blkmrkt_lung
THe problem with a highspeed laydown is you can't just asses damages based on aestheics. I'd Reccomend you take it to a certified service center and have them look at the internals for you. You could have knocked something loose. And more suprinsingly, im suprised you're bike is fixable after an 80 mph laydown. Hope you didn't get banged up too badly.
Old Sep 2, 2008 | 02:53 AM
justasquid's Avatar
It is possible its the plugs. the bestbet is to pull the plugs and lay the threaded part on a grounded surface such as a head bolt. Crank it over and see it fires. If it fires, its not your ignition and could be just a set of bad plugs.
Did the bike die when you crashed? Did the cylinders fill with oil from it laying on its side? If they did, it could have easily fouled your plugs.
There is a bank angle sensor that gets damaged fairly easily from a crash... if that fails, your bike wont start... but I'm not sure if won't crank at all, or just wont start.. Im pretty sure if it fails though, the fuel is cut off too, so probably not your issue.
Old Sep 2, 2008 | 06:00 PM
Default RE: 08 won'
good looking out fellas thanx for the advice, def will get the bike to dealer to get checked out, but for good measure i'll change the plugs before i go any furhter. thank you all
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
