06 1000rr Help!
Old Oct 6, 2006 | 09:46 AM
Blackrr1's Avatar
Default 06 1000rr Help!
I recently got my compounds put on the front and rear and ever since I have been noticing this shaking while braking downhill or braking into a small lean. I thought it might be out of balance or something but, I remembered that on 06's the front rim has two different sized bearings/spacers...I guess to offset it? does anyone know what side the longer spacer should be on the throttle or clutch side? Wouldnt this cause the shaking if its off by a couple mm? Si nce the calipers are radial mount it would make since. ANy ideas? Help?
Old Oct 6, 2006 | 01:52 PM
Blackrr1's Avatar
Default RE: 06 1000rr Help!
now I know the front spacers are different sized to offset the whell so the rotors are center with the calipers? Anyone know which spacer goes where?
ps...I posted this on r6messagenet and got a response quicker with less views...common cbr peeps. I expect better!
Old Oct 18, 2006 | 06:35 PM
Kendrick07's Avatar
that is the side collar you're referring to. I remember the bigger collar being on the throttle side. Someone correct me if I'm wrong
FrankTheTank707
Feb 27, 2012 05:15 AM
plasstik
May 14, 2011 09:53 PM
RaceIt454
Jul 22, 2009 12:14 AM
DEADBROKE
Dec 6, 2006 08:13 AM
