Yoshimura Pipes Question
Old Jun 26, 2013 | 11:16 AM
badrhino's Avatar
Default Yoshimura Pipes Question
How do you make the original Yoshimura exhaust pipes louder? They are rolled tighter than one of Cheech and Chongs joints. The baffle seems to be straight through but the diameter is small and the fiberglass packing is thick and tight as hell. I took the end cap off for the pictures and tried pulling on the baffle and it won't budge. I have no clue how to go about opening these things up for a beefier sound.
Any suggestions?
004-1.jpg Photo by badrhino | Photobucket
003.jpg Photo by badrhino | Photobucket
002-1.jpg Photo by badrhino | Photobucket
Old Jun 26, 2013 | 06:02 PM
Sprock's Avatar
center inner cone section incorporating the internal baffle/arrestor needs to be cut out
easiest way hammer a round piece of wood into the inner baffle then use a hole saw
to cut out - hole saw diameter needs to be smaller than the outer baffle tube
obviously
The KLR folks do something similar with stock KLR pipes - google is your friend
kinda like this
Old Jun 27, 2013 | 12:27 AM
badrhino's Avatar
Spock I did search for info and found nothing on the older style pipes. That looks like that should work. Thanks!
MikeG929
Jun 11, 2014 09:45 AM
EZRIDER4
Sep 10, 2013 02:20 AM
Firesnake
F2 Tech
Aug 7, 2013 01:47 PM
mitch Awsome
Oct 31, 2006 02:50 AM
cbrsilver
Mar 29, 2006 03:40 AM
