Where do these carb tubes go?
Old Feb 9, 2013 | 01:16 PM
re33's Avatar
Default Where do these carb tubes go?
If you have a sensitive disposition, look away now! Have built a CBR engine into a field racing buggy. Unfortunately I took the engine out of the bike 2 years ago so I can't remember what these pipes on the carbs connected to and can't get engine to start at the minute. Can anyone help? Thanks
Old Feb 9, 2013 | 06:47 PM
hawkwind's Avatar
I think they're just the drain pipes, so they don't connect to anything.
Old Feb 9, 2013 | 09:07 PM
MadHattr059's Avatar
#1 blue circle is the cooling to the carbs, I believe...
World of Powersports' 1996 Honda Street Bike CBR1000F Parts List.
#2 red is evaporative emission recycle from airbox (I'm guessing).
Hopefully someone can give you definitive answers.
Ern
Old Feb 10, 2013 | 01:25 AM
Shadow's Avatar
Yup - me too !
Maybe you haven't connected the hose to the vacuum port on the left hand carb - without it you get no fuel to the carbs......................
Old Feb 10, 2013 | 03:41 PM
re33's Avatar
Thanks for the suggestions. I think 2 is just a breather. Could 1 be the vacuums pipe? Where does the vacuum pipe on bike get low pressure from?
Old Feb 10, 2013 | 03:50 PM
Sprock's Avatar
Reds are just vent hoses and typically wrap around the backside of the tank from left
and right
Blue is a breather for the top of the carbs / diaphragms - typically you'd put a little foam
filter on to stop crud working it's way in there
Both vent line should trail the direction of travel for the motor to prevent water and stuff
getting pushed into it.
So is there a bigger pic of the buggy ?
Last edited by Sprock; Feb 10, 2013 at 03:55 PM. Reason: correction - om colour blind :-))
justice1327
Jul 24, 2013 08:52 PM
cc rider
Mar 30, 2013 07:59 PM
Damo77
CBR1000F Wanted / Swap
May 21, 2012 06:12 AM
Sand.Man
Apr 21, 2010 08:36 AM
