what a good plug to use
Old May 1, 2005 | 12:34 PM
greymustang's Avatar
Default what a good plug to use
what is a better plug to use than
ngk had a new set put in when the bike was being
work on and have already fowled them in about
1000 miles
Old May 2, 2005 | 12:17 AM
JasonW's Avatar
Default RE: what a good plug to use
Is your choke stuck on? If you have removed the choke cable from the carbs lately, it's not difficult to reinstall it in such a way that it won't close completely.
Old May 2, 2005 | 01:07 AM
the choke is working fine i check it and same to be ok
do you think if i run hotter plug it would do better
thanks for the help
Old May 2, 2005 | 10:31 AM
Trips's Avatar
I have been running a set of NGK iridum spark plus for 25,000km with no probs.
They have only now started to foul because of bike running rich. Probably carb problem above or floats.
Old May 3, 2005 | 12:48 AM
JasonW's Avatar
GM, I got your PM but had trouble replying. Hope everything is going ok for you. I'll keep an eye on the mailbox...
Thanks for staying in touch.
Jason
mgrandon
Sep 6, 2012 04:33 AM
dodger79
Aug 10, 2012 08:59 AM
pipedcbr
Dec 29, 2010 12:25 PM
bowflexmaverick
Oct 24, 2010 11:44 PM
allnath3
Nov 5, 2006 12:31 PM
